I've a product node configured with a number of variant child nodes.
If I set the stock level for one of the variants and publish the node it sets the same stock level for the parent product node and all of the other variant child nodes.
This would be quite a serious problem for anyone wanting to make use of stock.
Do you only have SKU at the parent node? If so - stock is saved using SKU and that is why the stock is the same for each variant. You need to assign unique SKU's to each variant to use individual stock for them.
Problem with setting the stock level on a product variant in 2.3.3
I think I've found a bug in 2.3.3.
Regards,
Matt
Hi Matt
Kind regards
Anders
Ah, thanks Anders.
That was the answer and a good feature if you think about it.
Regards,
Matt
