  • Mikkel Johannsen 32 posts 185 karma points
    Mar 28, 2017 @ 08:46
    Mikkel Johannsen
    Tea Commerce volume discount different products
    Hi!
    I'm wondering if anyone has ever made a similiar discount method in Tea Commerce.
    Imagine this:
    Product A: $2
    Product B: $2
    So, normally, if I buy 3 units of product A, it'd be a total of $6. However, this shop wants to have volume discount, so if you buy 3 units of product A, the total should only be $4.
    If I buy 2 product A and 1 product B, the volume discount should be the same, and the total should still be $4 and not $6.
    But if I buy 4 products in total, the price should be $6, because I still get the 3-units volume discount.
    Now, the problem is, these products aren't variants of each other, they're completely seperate products. The only thing they definitely have in common, is the volume discount.
    I hope it makes sense.
    Anyone have any suggestions on how to approach this?
  • Anders Burla Johansen 2560 posts 8256 karma points
    Mar 29, 2017 @ 15:44
    I think you need to create your own award - either an order line award or order award, where you select which order lines to discount. Non of the current awards can handle this case.
    https://github.com/TeaCommerce/Tea-Commerce-for-Umbraco/tree/master/Source/TeaCommerce.Umbraco.Configuration/Marketing/Models/Awards
    https://github.com/TeaCommerce/Tea-Commerce-for-Umbraco/tree/master/Source/TeaCommerce.Umbraco.Application/Marketing/Awards
    Kind regards
    Anders
    Mar 29, 2017 @ 15:51
    Mikkel Johannsen
    Hi Anders
    Thank you for your helpful answer as usual :-)
    I ended up suggesting the webshop owner we solve the issue using bundles instead, but I'll keep your solution in mind next time.
    It's the first time I've heard of a webshop having those requirements, so it's not very often we stumble upon them :-)
