  • René Pjengaard 117 posts 700 karma points c-trib
    Jan 14, 2019 @ 11:46
    René Pjengaard
    Problem in calculation order
    Hi Support,
    is there a way to control the order of calculations in Tea Commerce?
    My problem is, that i want to find out, if the customer is entitled to free shipping. This works fine, both via the markering-module and a custom shipping-calculator. The problem is, that if the customer has added eg. a discountcode, the shipping-calculation calculates on behalf of the original price, and not the new discounted price.
    Is there a way i could handle the order of the calculation, so that i calculated the shipping AFTER the discount is added.
    Best regards René
  • Matt Brailsford 4103 posts 22066 karma points MVP 9x c-trib
    Jan 14, 2019 @ 11:51
    Matt Brailsford
    Hi Rene,
    Discounts are applied in the order they appear in the Marketing section so you can right click the Marketing node and choose sort to define the order in which they run. This should then allow you to apply the shipping discount after the discount code discount.
    Hope that helps
    Matt
    Jan 14, 2019 @ 12:01
    René Pjengaard
    ohhhh sweet jesus, how stupid can i be?!
    Thanks a lot Matt.
    By the way, is there a way to do the same in code?
    /R
    Jan 14, 2019 @ 12:04
    Matt Brailsford
    No problem.
    Do you mean sort the list by code? Or tell TC commerce to run discounts in a specific order?
    Either way I don't think either are currently possible, but could look at possibilities.
    Matt
    Jan 14, 2019 @ 12:09
    René Pjengaard
    More tell TC to run discounts/shipping calculator in a specific order.
    No problem right now. So nevermind. Once again, thanks for the super fast support.
    SuperTak!
    Jan 14, 2019 @ 12:14
    Matt Brailsford
    No problem.
    I'll keep this in mind when I come to doing some updates.
    Thanks for the feedback.
    Matt
