  • kristian schneider 190 posts 351 karma points
    Jan 12, 2011 @ 11:35
    kristian schneider
    Nodes do not get published
    Hi All.
    I'm struggling with a problem that seems a bit weird.
    When I try to publish something i my 4.5.2 solution they don't appear in the final rendering.
    This is what I know:
    • When publishing I get the "content published" speech bubble
    • Debug log says:
    Debug Administrator (none) 12/01/2011 10:22:50 Xml saved in 00:00:00.0201927
    • Error log says nothing:
    • Publish log says:
    Publish Administrator Life Map Exercise 12/01/2011 10:22:49
    • umbraco.config gets updated and I can see the published content in there
    • I can preview it.
    • The content is persisted in the database since I can see the changes in umbraco
    But It does not appear in the final rendering. For simplicies sake I tried to make a simple rendering with just a
    <umbraco:Item runat="server" Field="Content" />
    Because I thought it might be a caching issue.
    • If I recycle the app pool after the content is published it appears
    So for some reason it seems that the in memory xml representation does not get updated when publishing.
    Any suggestions?
    Best regards
    Kristian
    Jan 12, 2011 @ 11:48
    Kim Andersen
    Hi Kristian
    Is this an Umbraco installation with more than one website in it?
    If that's the case, there are some issues if you go to website1.com/umbraco/ and publishes something on website2.com. More details here: http://our.umbraco.org/forum/using/ui-questions/15741-Can-not-public-changes-i-2nd-website
    /Kim A
    Jan 12, 2011 @ 12:21
    kristian schneider
    Ha! That did it.
    And yes it is a solution with multiple websites
    Karma on its way
