  • Anthony Dang 1404 posts 2558 karma points MVP 3x c-trib
    Jul 05, 2011 @ 15:29
    Anthony Dang
    Error handling action No Document exists... - content node delete problem
    When I delete a node I get this error message:
    No Document exists with Version '00000000-0000-0000-0000-000000000000'
    The node is deleted properly. I have been programatically sorting and moving nodes. Is there anything that I might have tripped over?
    I do this after save:
    Document newParent = DocumentHelper.GetCorrectParentForPost(date, sender);
    if (newParent.Id != sender.ParentId)
        sender.Move(newParent.Id);
        DocumentHelper.SortPostsByDate(newParent.Children, sender);
    And here is my sorting method:
      /// <summary>
    /// </summary>
    /// <param name="posts"></param>
    /// <param name="document"></param>
    public static void SortPostsByDate(IEnumerable<Document> posts, Document document)
        // remove the search node from the list
        IEnumerable<Document> documents = posts.Where(x => x.Id != document.Id);
        DateTime newDate = DateTime.Parse(document.getProperty("uBlogsyPostDate").Value.ToString());
        var nodeSorter = new umbraco.presentation.webservices.nodeSorter();
        string sortOrder = string.Empty;
        if (documents.Count() == 0)
            return;
        if (newDate > DateTime.Parse(documents.Last().getProperty("uBlogsyPostDate").Value.ToString()))
            // new document should be at the end
            sortOrder = string.Join(",", documents.Select(x => x.Id)) + "," + document.Id;
            nodeSorter.UpdateSortOrder(document.ParentId, sortOrder);
            return;
        bool found = false;
        foreach (var d in documents)
            if (newDate <= DateTime.Parse(d.getProperty("uBlogsyPostDate").Value.ToString()))
                // insert post here!
                if (!found)
                    sortOrder += document.Id + ",";
                    found = true;
            sortOrder += d.Id + ",";
        nodeSorter.UpdateSortOrder(document.ParentId, sortOrder.TrimEnd(','));
  • kristian schneider 190 posts 351 karma points
    Jul 05, 2011 @ 15:38
    kristian schneider
    Where do you see the error? In the backend or as an exception?
    Jul 05, 2011 @ 16:59
    Anthony Dang
    It's happening on right-click delete.
    I commented out the sorting and it seems that i have the same issue. Possibly not related to any of this.
    The log file shows this:
    Error adding to SiteMapProvider: System.InvalidOperationException: Multiple nodes with the same URL '/' were found. XmlSiteMapProvider requires that sitemap nodes have unique URLs.
       at System.Web.StaticSiteMapProvider.AddNode(SiteMapNode node, SiteMapNode parentNode)
       at umbraco.presentation.nodeFactory.UmbracoSiteMapProvider.loadNodes(String parentId, SiteMapNode parentNode)
    Any thoughts?
    Jul 05, 2011 @ 17:34
    Anthony Dang
    Oh recycle bin!
    I found the problem!
    I'm accessing the document on the after move event. Deleting a document fires the move event and hence the after move event.
