  • Chris 11 posts 30 karma points
    Nov 30, 2011 @ 12:05
    Chris
    Search case sensitivity
    I would like the search to be case insensitive. So "SearchTerm" returns the same results as "searchterm" is this possible. Here is my query if that helps
               var criteria = ExamineManager.Instance
                    .SearchProviderCollection["InternalSearcher"]
                    .CreateSearchCriteria();
                var filter = criteria
                    .GroupedOr(new string[] { "nodeName", "bodyText","summary"},
                               searchTerm)
                    .Compile();
                SearchResults = ExamineManager.Instance.SearchProviderCollection["InternalSearcher"]
                    .Search(filter);
    Nov 30, 2011 @ 12:58
    Dirk De Grave
    Have a look at this thread, and especially the reply by Aaron. (slace), it may be an answer to your question.
    /Dirk
    Nov 30, 2011 @ 13:22
    Chris
    Hi I've tried creating another index set based on the Standard Analyers but it won't return anything and when I look at the index (using the Examine Dashboard Package) it says there are no documents in the index and it is in the queue. Here is some of the configs. Bear in mind I'm a total newbie.
     <IndexSet SetName="FrontEndIndexSet" IndexPath="~/App_Data/TEMP/ExamineIndexes/FrontEndMember/">
        <IndexAttributeFields>
          <add Name="id" />
          <add Name="nodeName"/>
          <add Name="updateDate" />
          <add Name="writerName" />
          <add Name="loginName" />
          <add Name="email" />
          <add Name="nodeTypeAlias" />
        </IndexAttributeFields>
        <IndexUserFields/>
        <IncludeNodeTypes/>
        <ExcludeNodeTypes />
      </IndexSet>
      <ExamineIndexProviders>
        <providers>
          <add name="InternalIndexer" type="UmbracoExamine.UmbracoContentIndexer, UmbracoExamine"
               supportUnpublished="true"
               supportProtected="true"
               interval="10"
               analyzer="Lucene.Net.Analysis.WhitespaceAnalyzer, Lucene.Net"/>
          <add name="FrontEndIndexer" type="UmbracoExamine.UmbracoMemberIndexer, UmbracoExamine"
               interval="10"
               analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net"/>
          <add name="InternalMemberIndexer" type="UmbracoExamine.UmbracoMemberIndexer, UmbracoExamine"
               interval="10"
        </providers>
      </ExamineIndexProviders>
    <ExamineSearchProviders defaultProvider="InternalSearcher">
        <providers>
          <add name="InternalSearcher" type="UmbracoExamine.UmbracoExamineSearcher, UmbracoExamine"
          <add name="FrontEndSearcher" type="UmbracoExamine.UmbracoExamineSearcher, UmbracoExamine"
               analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net" enableLeadingWildcards="true"/>
          <add name="InternalMemberSearcher" type="UmbracoExamine.UmbracoExamineSearcher, UmbracoExamine"
        </providers>
      </ExamineSearchProviders>
