  • Babajide 26 posts 46 karma points
    Aug 30, 2012 @ 21:36
    Babajide
    Umbraco Examine cant search for input with two words
    Hello, my search works when an input like "testimonial" is searched for, but an input like "about us" returns 0 results. I've seen a forum post where people used "split" and "GroupedOr" but i cant get it to work in my code. Here's my code:
    public string Term getset}
        public int Count getset}
            protected void Page_Load(object senderEventArgs e)
                if (!String.IsNullOrEmpty(Request.QueryString["s"]))
                    Term Request.QueryString["s"].ToString();
                    if (Term.Length 1)
                        //Create search Criteria
                        var sc ExamineManager.Instance.CreateSearchCriteria();
                        //define query
                        var query sc.NodeName(Term.MultipleCharacterWildcard())
                        .Or()
                                    .Field("block1"Term.MultipleCharacterWildcard())
                        .Or()
                                    .Field("block2"Term.MultipleCharacterWildcard())
                        .Or()
                                    .Field("block3"Term.MultipleCharacterWildcard())
                        .Or()
                                    .Field("blockTitle1"Term.MultipleCharacterWildcard())
                        .Or()
                                    .Field("blockTitle2"Term.MultipleCharacterWildcard())
                        .Or()
                                    .Field("blockTitle3"Term.MultipleCharacterWildcard())
                        .Or()
                                    .Field("siteName"Term.MultipleCharacterWildcard());
                        //   .Or()
                        //   .Field("summary"Term.MultipleCharacterWildcard());
                        //or search by keyword
                        var results ExamineManager.Instance.SearchProviderCollection["WebsiteSearcher"].Search(Termtrue);
                        rp_results.DataSource results;
                        Count results.Count();
                        rp_results.DataBind();
    Thanks in advance.
    Aug 31, 2012 @ 10:53
    Ismail Mayat
    babajide,
    You need to do var terms = Term.split(' ');
    foreach(var t in terms){
    //use t as query input with Or
    Regards
    Ismail
    Aug 31, 2012 @ 11:34
    Ismail Mayat
    Also why are you doing
    if should be
    var results ExamineManager.Instance.SearchProviderCollection["WebsiteSearcher"].Search(query.Compile());
  • Funka! 398 posts 661 karma points
    Aug 31, 2012 @ 19:20
    Funka!
    I wonder if this is the same problem I've noted with the admin backend UI search (you know, the thing in the top-left corner) where you only get results if you search for a single word, but never get any results if you include two or more. Hmmm....
