When a customer tries to login he gets following error:
usernoconsole
Also, your user account might not have been set-up correctly, the following SQL is executed for your user, maybe the "usernoconsole" column doesn't have the correct value?
public static int getUserId(string lname, string passw) { return getUserId("select id from umbracoUser where userDisabled = 0 and userNoConsole = 0 and userLogin = @login and userPassword = @pw", SqlHelper.CreateParameter("@login", lname), SqlHelper.CreateParameter("@pw", passw)); }
Usernoconsole error when logging in
Its a 4.0.2.1 installation with MS SQL
This older post might help..?
public static int getUserId(string lname, string passw) {return getUserId("select id from umbracoUser where userDisabled = 0 and userNoConsole = 0 and userLogin = @login and userPassword = @pw",
We restarted the IIS and then it started to work again. The table umbracoUser table looked fine.
I couldnt find anything related in the old post.
I little bit troublesome if it should happen again!
Following steps worked for me In my case it was Umbraco 7.4.2
1) setting "userNoConsole" to 0 (executing following sql query Umbraco DB)
update [umbracoUser] set userNoConsole = 0 where UserLogin='Admin' -- respective user
2) restarting website from IIS OR can also touch web.conf to do so.
