  • Emil Christiansen 66 posts 148 karma points
    Mar 02, 2015 @ 13:50
    Emil Christiansen
    Dublicate nodes in media-archive when using custom datatype/usercontrol
    Hi there!
    I'm having a weird problem:
    On an Umbraco 6.2.4 using WebForms as the default rendering engine, i have a custom usercontrol.
    I have created a new custom datatype which uses the "Umbraco Usercontrol Wrapper" and my custom usercontrol. The usercontrol inherits umbraco.editorControls.userControlGrapper.IUsercontrolDataEditor and implements the IUsercontrolDataEditor interface.
    In the "Settings" section of Umbraco i have created a new property on the "Folder"-mediatype under the "Mediatypes" which uses my custom datatype.
    If i then go to the media-section and click on one of the media-folders and navigate around between the Umbraco sections - dublicate nodes of some of the media-folders show up. And if i toggle between the "developer" and "media" sections in Umbraco - the names of the media-folders are concatted each time making the folder nodenames longer and longer.
    I have tried with an "empty" usercontrol without any logic - and the problem still occur.
    I have tried an application-recycle and restart of the website in the IIS without any luck.
    Does anybody know what is going on - or have any idea what could be causing this odd behaviour?
    Thanks in advance!
  • Mads Krohn 211 posts 504 karma points c-trib
    Mar 03, 2015 @ 09:00
    Mads Krohn
    IIRC we are experiencing a similar issue on a 6.2.4 project as well. So for now, I'm just here to listen :)
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Mar 03, 2015 @ 09:14
    Jeroen Breuer
    I've had this before with a custom tree: https://twitter.com/j_breuer/statuses/392277579513597953
    Are there somehow nodes in the tree that have the same id?
    Jeroen
    Mar 03, 2015 @ 09:33
    Emil Christiansen
    Hi Jeroen
    Not sure what id's you are talking about :) ?
    The nodes which are shown multiple times have the same node id's - but they should (of course) only be shown once each.
    Look at the picture below for an example:
    The custom usercontrol in the example below lies on the image-mediatype. And as posted above - the problem also occurs if it is just a plain clean usercontrol. If i remove the usercontrol - the problem is gone.
    A couple of times i have somehow managed to get rid of the dublicate nodes. But an application-restart, site restart, web.config touch and so on doesn't seem to do the trick.
    When the duplicate nodes disappear - i am not able to provoke the problem again... well, that is until it suddenly appears by itself again :|
    /Emil
    Mar 03, 2015 @ 09:39
    Jeroen Breuer
    I'm talking about the id of the node. You can find it on the properties tab. If something like this happens you might have a "ghost" node somewhere. When you sort the media do you see a duplicate node?
    These topics might help:
    https://our.umbraco.org/forum/core/general/17462-Missing-nodes-in-backend?p=1#comment68851
    https://our.umbraco.org/forum/developers/extending-umbraco/32558-Ghost-nodes-in-Content-Tree
    Jeroen
    Mar 03, 2015 @ 10:06
    Emil Christiansen
    If i sort the nodes - the problem is gone.
    The funny thing is - when i right click and choose "sort" i see no duplicate nodes as in your examples from the links.
    The problem occurs almost everywhere in the media archive and disappears when i remove the usercontrol - it doesn't make sense to me that this problem is due to ghost nodes in the db if i can remove the problem "just" by deleting the usercontrol?
    How should i be able to find the dublicate nodes in the db?
    I have tried seachring for the name of the node in umbracoNode table - but only one node turns up.
    /Emil
    Aug 10, 2015 @ 08:38
    Emil Christiansen
    Still experiencing this odd behavior!
    A quick summary of the problem:
    A clean usercontrol on the image-mediatype results in ghost-nodes in the media archive.
    No nodes in the tree with same id. No ghost-nodes can be found in the database. If i right click and choose "sort" - no dublicate nodes exist. If i sort the nodes - the problem is gone - at least for a while.
    Nobody with a good idea or fix ?
    Thanks!
