When I log into umbraco, there is no nodes showing in any of my sections, besides the root nodes (Content, developer etc.). My frontend works just fine, and I have tried to delete my umbraco.config-file, and republish the entire site agin. This doesn't help. I have also tried to reload my nodes of course but with no luck.
Hi. I work on the same project and have been looking into the problem as well
We have checked that. Persmissions are set to full access to "Network service" and files are readable. I can also add that the ajax toolkit is a 1.01* version.
This appears in the umbraco error log:
At /umbraco/tree.aspx?rnd=869a982c-5fcf-4964-a405-ac2c109090dc&id=-1&contextMenu=true&isDialog=false&app=developer (Referred by: http://vps190.vpswin.dk/umbraco/TreeInit.aspx?app=developer): System.InvalidOperationException: Unable to generate a temporary class (result=1). error CS2001: Source file 'C:\WINDOWS\TEMP\vvv7udxb.0.cs' could not be found error CS2008: No inputs specified at System.Xml.Serialization.Compiler.Compile(Assembly parent, String ns, CompilerParameters parameters, Evidence evidence) at System.Xml.Serialization.TempAssembly.GenerateAssembly(XmlMapping[] xmlMappings, Type[] types, String defaultNamespace, Evidence evidence, CompilerParameters parameters, Assembly assembly, Hashtable assemblies) at System.Xml.Serialization.TempAssembly..ctor(XmlMapping[] xmlMappings, Type[] types, String defaultNamespace, String location, Evidence evidence) at System.Xml.Serialization.XmlSerializer.GenerateTempAssembly(XmlMapping xmlMapping, Type type, String defaultNamespace) at System.Xml.Serialization.XmlSerializer..ctor(Type type, String defaultNamespace) at umbraco.BusinessLogic.Utils.SerializableData.Serialize(Object objDeserialized, Type objectType) at umbraco.cms.presentation.Trees.XmlTree.ToString() at umbraco.cms.presentation.tree.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
I don't claim to know the answer, but one of the messages in the exception is calling out to me:
System.InvalidOperationException: Unable to generate a temporary class (result=1). error CS2001:Source file 'C:\WINDOWS\TEMP\vvv7udxb.0.cs' could not be foun
Check the Network Service permissions on the WINDOWS\TEMP directory?
Well, back then when we had the problem, the site was running on Umbraco 4.0.2.1 with an application pool running in classic mode. Don't know if an iisreset helps anything, but it's worth a shot :)
No nodes ind the backend
When I log in i only see this image: NoNodes
I have also tried to create a new node, and this worked fine, but the node didn't show up in my tree either :(
What can I do?
Check permission settings on your umbraco folder, as this is mostly the cause of this
/Dirk
H Kim and Kristian,
Good luck, Lee.
Thanks Lee. This fixed the problem :)
Ahh. Hit the wrong button, and gave a 1+ instead of the "correct aswer"-button, and now I can't mark this issue as solved.
Hi Kim, if you refresh the page - the "mark as solution" button should reappear. (I think).
Glad your problem is sorted!
Thanks, Lee.
I have the exact same problem. Could anyone tell me exactly what permissions to give?
//Kalle
Hi Kalle
What we did to solve this problem was to give the NETWORK SERVICE full access to the "Windows/Temp"-folder. That solved the problem for us back then.
/Kim A
Hi again Kim.
I still have the problem for some of my sites, even tough I have the right permissions on both the umbraco folder and the windows - temp folder.
Do you need to restart the IIS or something?
//Kalle
Also, should the application pool run in integrated or in classic mode?
/Kim A
Hello again,
I still have this problem on my sites. When I do an IIS reset it works for some hours, and then back to not shoeing any nodes!
I have set the full permissions for NETWORK SERVICE to c:\windows\temp and all the required folders in umbraco-folder.
Any ideas?
In the logfiles I get this:
At /umbraco/tree.aspx?rnd=b4891ba2-04ab-4a99-87a8-6b0581f30cdf&id=-1&treeType=content&contextMenu=true&isDialog=false (Referred by: http://www.tidbecks.se/umbraco/TreeInit.aspx): System.IO.FileNotFoundException: Could not find file 'C:\Windows\TEMP\cg_z_x1b.dll'. File name: 'C:\Windows\TEMP\cg_z_x1b.dll' at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at Microsoft.CSharp.CSharpCodeGenerator.FromFileBatch(CompilerParameters options, String[] fileNames) at Microsoft.CSharp.CSharpCodeGenerator.FromSourceBatch(CompilerParameters options, String[] sources) at Microsoft.CSharp.CSharpCodeGenerator.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromSourceBatch(CompilerParameters options, String[] sources) at System.CodeDom.Compiler.CodeDomProvider.CompileAssemblyFromSource(CompilerParameters options, String[] sources) at System.Xml.Serialization.Compiler.Compile(Assembly parent, String ns, XmlSerializerCompilerParameters xmlParameters, Evidence evidence) at System.Xml.Serialization.TempAssembly.GenerateAssembly(XmlMapping[] xmlMappings, Type[] types, String defaultNamespace, Evidence evidence, XmlSerializerCompilerParameters parameters, Assembly assembly, Hashtable assemblies) at System.Xml.Serialization.TempAssembly..ctor(XmlMapping[] xmlMappings, Type[] types, String defaultNamespace, String location, Evidence evidence) at System.Xml.Serialization.XmlSerializer.GenerateTempAssembly(XmlMapping xmlMapping, Type type, String defaultNamespace) at System.Xml.Serialization.XmlSerializer..ctor(Type type, String defaultNamespace) at System.Xml.Serialization.XmlSerializer..ctor(Type type) at umbraco.BusinessLogic.Utils.SerializableData.Serialize(Object objDeserialized, Type objectType) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\businesslogic\Utils\SerializableData.cs:line 43 at umbraco.cms.presentation.Trees.XmlTree.ToString() in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\Trees\XmlTree.cs:line 73 at umbraco.cms.presentation.tree.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\tree.aspx.cs:line 52 at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\businesslogic\BasePages\BasePage.cs:line 287 at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
