Developer documentation
Developer documentation covers working with Umbraco Forms from a developer standpoint. It covers retrieving data, it shows how to extend the system by hooking into the provider model, and finally it describes the available events and workflows you can use to extend or integrate Umbraco Forms.
Preparing your Frontend
Before adding a form to your site we'll need to make sure you have the necessary client dependencies.
Rendering Forms scripts where you want
Control where you want Forms to render its JavaScript.
Themes
Easier & more control of rendering Form HTML markup and styling using Themes that replaces the previous methods in version 4.x
Custom markup
Write your forms your way. You have full control over your form's HTML markup and styling.
Creating custom HTML emails
Version 6.0.0+ - Send custom HTML email templates using the new workflow 'Send email with template (Razor)'.
Working with Record data
See how you can fetch and display record data from your Razor macros.
Extending
Learn how you can extend Umbraco Forms with your own custom providers.
Configuration
Learn about some of the configuration options that are available to you to modify how Umbraco Forms works.
Magic strings
Learn about the magic string formats that Umbraco Forms supports, that can retrieve information from various sources such as Session, Cookies, Umbraco Page Fields, Member fields, Form fields to use in workflows.
Storing Form Files with IFileSystem
Version 4.4.0+ - Learn how you can implement a custom IFileSystem to store the Forms, Workflows, PreValues and other JSON-based files to suit your needs.
