Build your own editor
    The samples in this section have not been verified against the latest version of Umbraco.
    A new Property Editor called the Block based Grid editor will soon be available as a substitute for the existing Grid Layout editor. For more information, see the Block based Grid editor for Umbraco CMS in the Umbraco Roadmap.
    Create a file in /App_Plugins/yourpackage/editor.html and add the following to the editor.html file:
    <textarea rows="1" umb-auto-resize ng-model="control.value" ng-style="control.editor.config"></textarea>
    Save the file and add an editor to the /App_Plugins/yourpackage/package.manifest file:
        "gridEditors": [
                "name": "Code",
                "alias": "code",
                "view": "/App_Plugins/yourpackage/editor.html",
                "icon": "icon-code",
                "config": {
                    "color": "red",
                    "text-align": "right"
    Add a new file: /App_Plugins/yourpackage/editor.cshtml - this file will handle rendering the entered data - this path is done by convention so:
    • view: 'editor' => views/partials/grid/editors/editor.cshtml
    • view: '/App_Plugins/path.html' => /App_Plugins/path.cshtml
    If you wish to use something entirely different you can give the editor a separate render value which follow the same conventions.
        "name": "Code",
        "alias": "code",
        "render": "/App_Plugins/yourpackage/custom-render.cshtml"
    Grid editor controller
    If you are building something slightly more complex then a text area, you will need to add a controller to the grid editor view. So first add a ng-controller attribute to the grid editor html - this works like building a property editor:
    <div ng-controller="my.custom.grideditorcontroller">
        <textarea>...</textarea>
    To wire up a controller to this view, create the file /App_Plugins/yourpackage/editor.controller.js and add a standard angular controller declaration:
    angular.module("umbraco").controller("my.custom.grideditorcontroller", function ($scope) {
        $scope.control.value = "my new value";
    Finally, we need to tell Umbraco to load this JavaScript controller when the Umbraco application boots. This is like building a property editor. Add your JavaScript (and css dependencies) in the package.manifest file in the /yourpackage folder, and configure it to load your controller file.
        "gridEditors": [
                "name": "Code",
                "alias": "code",
                "config": {
                    "color": "red",
        javascript:[
            "/App_Plugins/yourpackage/editor.controller.js"
    So to summarize, to create a custom grid editor from scratch, you will need to:
    • Create a grid editor view .html file
    • Create a grid render .cshtml file
    • Create a grid editor controller .js file
    • Create a package.manifest to register the editor and make Umbraco load needed files
    This process tries to be as close to building property editors as currently possible.
    Rendering grid editor content
    Next add this c# to the .cshtml file:
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<dynamic>
    <pre>@Model</pre>
    When rendering the .cshtml file will receive a dynamic model with the raw data of the editor:
        "value": "What ever value entered into the textarea",
        "editor": {
            "name": "Code",
            "alias": "code",
            "config": {
                    "color": "red",
    So you can now use these value to build your razor output like so:
    <div style="color: @Model.config.color">@Model.value</div>
