An automated guess is that docs.umbraco.com/umbraco-cms/tutorials/porting-packages-v8/ could be the link to the new documentation for Umbraco 9 and newer versions.
    Porting packages to V8
    This is not a definitive guide for all scenarios but more of a working document which will evolve over time, especially as Umbraco 8 matures. Due to this, please keep in mind that things in this guide may change.
    You have a useful Umbraco package built for Umbraco 7 and you would like to see it work for Umbraco 8? This guide should give you a few pointers to get you started with the process and is mostly geared towards solutions that use C#.
    Upgrade .NET Framework
    Upgrade your Visual Studio C# project to use and compile against the .NET Framework 4.7.2. This is because the minimum .NET Framework to run version 8 of Umbraco requires this specific version.
    Add references via Nuget
    You will need to add UmbracoCms.Core via Nuget using the UI in Visual Studio or the Nuget Command Line with the following command
    Install-Package UmbracoCms.Core
    Optionally add a reference to UmbracoCms.Web if your code uses things like UmbracoApiController or SurfaceController. You will need to add the Nuget package reference of UmbracoCms.Web which in turn has a reference to UmbracoCms.Core
    Install-Package UmbracoCMS.Web
    Try & build the solution
    OK now the references have been updated, try and build the solution to see if any errors pop up.
    Fix up compile errors
    As long as your Umbraco package was not using outdated APIs and is using the new APIs & Services in Umbraco V7 then most of this step will be trying to determine what the new V8 namespace equivalent is.
    Clone down the Umbraco CMS source code and checkout the v8/dev branch. Use this as a way to try and find the same method that the compiler is complaining about in its new namespace.
    Bye bye ApplicationEventHandler, Hello Composer & Components
    A common thing that most package developers and Umbraco developers use in their projects is an ApplicationEventHandler to do some logic at the startup of Umbraco or to register event listeners based on Umbraco events such as ContentService.Saved etc.
    In Umbraco version 8 this has been removed and replaced with Composer & Components.
    Old ApplicationEventHandler way
    using System.Linq;
    using Umbraco.Core;
    using Umbraco.Core.Events;
    using Umbraco.Core.Models;
    using Umbraco.Core.Services;
    using Umbraco.Web.Routing;
    namespace Umbraco.Web.UI
        public class RegisterEvents : ApplicationEventHandler
            protected override void ApplicationStarting(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
                base.ApplicationStarting(umbracoApplication, applicationContext);
                ContentLastChanceFinderResolver.Current.SetFinder(new My404ContentFinder());
            protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
                //Listen for when content is being saved
                ContentService.Saving += ContentService_Saving;
            private void ContentService_Saving(IContentService sender, SaveEventArgs<IContent> e)
                foreach (var content in e.SavedEntities
                    //Check if the content item type has a specific alias
                    .Where(c => c.ContentType.Alias.InvariantEquals("MyContentType"))
                    //Check if it is a new item
                    .Where(c => c.IsNewEntity()))
                    //check if the item has a property called 'richText'
                    if (content.HasProperty("richText"))
                        //get the rich text value
                        var val = c.GetValue("richText");
                        //if there is a rich text value, set a default value in a
                        // field called 'excerpt' that is the first
                        // 200 characters of the rich text value
                        c.SetValue("excerpt", val == null
                            ? string.Empty
                            : string.Join("", val.StripHtml().StripNewLines().Take(200)));
    New Composer & Component way
    using System.Linq;
    using Umbraco.Core;
    using Umbraco.Web;
    using Umbraco.Core.Composing;
    using Umbraco.Core.Services.Implement;
    namespace MyProject.Components
        public class MyComposer : IUserComposer
                composition.SetContentLastChanceFinder<My404ContentFinder>();
                composition.Components().Append<MyComponent>();
        public class MyComponent : IComponent
            public void Initialize()
                ContentService.Saving += this.ContentService_Saving;
            public void Terminate()
                //unsubscribe during shutdown
                ContentService.Saving -= this.ContentService_Saving;
            /// <summary>
            /// Listen for when content is being saved, check if it is a
            /// new item and fill in some default data.
            /// </summary>
                    .Where(c => c.HasIdentity == false))
                        var val = content.GetValue<string>("richText");
                        content.SetValue("excerpt", val == null
                            ? string.Empty
                            : string.Join(string.Empty, val.StripHtml().StripNewLines().Take(200)));
    Update package.xml for Umbraco ZIP packages
    As version 7 and version 8 of Umbraco have breaking changes in their APIs and code, it's recommended to ship a different version of your package to support Umbraco 8 only. You'll need to update the package.xml in your Umbraco package zip to use the 8.0.0 version like so.
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <umbPackage>
      <info>
        <package>
        <name>My Umbraco Package</name>
        <requirements>
            <major>8</major>
            <minor>0</minor>
            <patch>0</patch>
        </requirements>
    Optional - Update .nupkg dependencies
    If you ship your package as a Nuget package, then you will need to add/update references to the UmbracoCms.Core or UmbracoCms.Web nupkg from the MyGet feed https://www.myget.org/F/umbracocore/api/v3/index.json
    Initial testing
    Now you have updated and re-created a new package, it's time to test out your package be it via installing a local Umbraco ZIP package or installing it into a Website project via Nuget. You may have some final tweaking in relation to the UI as some parts of the Umbraco angular directives & components have changed slightly. This may require you to tweak some of your Angular views & Javascript accordingly so that it feels more at home in the Umbraco 8 backoffice.
